Ohm through converter?
Reno
Website
www.about.me
Shouldn't I be able to ohm through a 3 to 2 brake/turn wire converter? I've tried to ohm through 4 -- the first one didn't work the other three I tried at the store.
not necessarily. going to have some solid state electronics in it, such as a transisitor, and diode, so likely not able to "ohm through" it without a trigger voltage present. Probably needs a trigger to a transistor to allow certain legs to ohm in the vicinity of 0 ohms.
I am guessing you want to convert your 3 wire taillights(amber turn) to 2 wire(combo turn/brake)...
Have you put a load on the input side of the converter? Without a load on it, it wont properly flash. or you could get a HD turn signal flasher, that has its own internal load, and flashes the blinkers a a set speed irregardless of the number of bulbs present...
It's all diodes,the simplest form of a logical OR gate. You can check continuity if you bias them right. You need the right DVOM, ie one that will apply at least 0.7 Volts. Usually there will be a diode check mode if the DVOM can do it. Check with the red (pos) lead on the vehicle side. It's easier to read voltages.
Correct you both are!
I did have the HD flasher already.
But I had not taken the biase voltage into account.
That probably killed 2 trips to Ace!
I'm all good now.
Thanks.
