Offset question
ELK GROVE, CA
Hi All,
Looking into buying some wheels and the wheel spec I'm looking at is 16x8 w/ -20 offset, 6x139.7.
My question is with these specs, will the wheel be flushed, tucked in or sticking out a little bit from the wheel well?
I don't want to use spacers and love the flushed or the sticking out a little bit from the wheel well look.
Thank you for any input y'all may provide.
Negative offset will push it out further, basically 20mm further than a stock wheel which should be a zero offset AFAIK. My current wheels have a -25mm offset with 315/75/16s on them, and the rubber sticks out around a half inch or so past the fender flares.
