Thought I would finally start up a post for my rig, Will be my first 4 x 4 Still have alot of progress towards this build but have started on some basic stuff. Just abit about myself Im a 24 Year old guy from New Zealand, Yes that island all the way at the bottom of your map, If were even on there
Anyway...
1993 FZJ80 Landcruiser imported from Japan. Mostly stock expect for a LPG kit added in (Will be removed) (Sat for over 6 Years)
Mostly the difference between North America and Japan models are obviously left hand drive and right hand drive. All interior dash flipped, Brake Booster, OBD Port ( Im sure there is quite abit more)
What has been done so far:
Almost finished with fixing up clear coat and a few rust patches on exterior panels
Oil Change (Filter, Trans Flush, Radiator Flush,
Removed LPG Kit, (LPG Lines, LPG Cooling Lines, Tank Indictor)
Fixed VAF Issues, LPG had previous backfired and blown up a few VAFS in its time....
Got some New Vacuums lines that were cracked and needed to be replaced.
New set of Wheel bearings
Removed 3rd Row Seats
Removed Factory Bull Bar (For Now)
New Alternator
Set Dizzy to 3 Degrees
New Radiator Cap
Cleaned all carpets and Seats
Removed stock radio
New Fuel pump
New Fuel Filter
New Spark Plugs
What Needs to be done:
Address hard shifting into low range
Diff Oils Etc
Lift Kit
New Mags and Tyres
Need to Remove LPG Fuel Tank
Next Post will be about what is in progress right now!
Any suggestions on what should be looked at and replaced is always appreciated!
Anyway...
New Alternator
New Radiator Cap
Removed stock radio
New Fuel pump
New Fuel Filter
New Spark Plugs
Diff Oils Etc
Lift Kit
New Mags and Tyres
