Off Road Lights Theft Prevention
South Kansas City, MO
I think I saw somewhere a post saying to add a nut on the bottom of the stud and weld it on. Are there any other options for securing your off road lights? or is this the best way?
depending on what type of lights you have, there are some nuts( work similar to the gorilla wheel locks) you can buy. I have a product called barrinuts for my ipfs. Google them and you'll know what i'm talking about.
I put two nuts on the studs stacked onto of each other. The last nut has all the edges grounded/rounded down to a circle. The only way you can take it off is with a plumber's wrench, something that most thieves don't carry around. You can use only one rounded off nut for each bolt if the stud of the bolts are short.
I had the boys in the workshop up on the mine where I work make me up two tubes about an inch long with a washer welded at one end. I then unbolted my off road lights and rebolted them with the nyloc nut inside the tube. I then tightened everthing using a tube socket and added a second nyloc nut for time wasting sake. I then drilled a hole through the tube and put a hightensile bolt through the hole which I nyloced till I get the padlocks. This should be enough to stop honest people from stealing the lights. Sorry if this sounds confusing but it does work.
http://i104.photobucket.com/albums/m162/alby_39/IMG_3420.jpg
http://i104.photobucket.com/albums/m162/alby_39/IMG_3418.jpg
Cheers
Alby
Cheers
Alby
Clever idea Alby! :cheers:
PIAA sells some sort of locking nut for their lights. Haven't looked into it further than that tho.
I've got locks on my IPFs. Not sure who makes them though.
Edit, the fawkers around here have stolen my light covers too, so I cable tie them on now.
