Off center steering shaft
Astoria, Oregon
I was diagnosing a short in my horn circuit. When I pulled the steering wheel, I saw that the shaft was off center. The rubber bushing had worn through on the bottom and shorted the horn wire. I can’t see my to find a replacement bushing so I think I am going to 3d print one. But I need to get the shaft recentered in the tube. I have tried prying and putting a shim in but I can’t get it to move much. Any ideas?
Crazy timing, I just designed and printed a part for this as of yesterday. It's printed out of TPU, solid fill. I did probably 5 or 6 test prints in PLA for fitment and tweaks to the design.
I have the inner sleeve as well, but my stock one was in good shape so I just used that because the tolerance between tight and loose was slim and the 3D printed layer lines at about 0.8mm thick are just not very strong. The material also should be nylon ideally.
I also designed and printed (TPU) the horn spacer from dimensions provided in other threads. Fit's perfect.
In regards to the actual alignment, when mine was apart like yours is now, the shaft was still pretty much centered. It had a little bit of play, but I wouldn’t say more than a 1/4” or so. If I had to guess, I’d say the shaft has bent itself down over time.
Put a section of pipe over the shaft and pull up. Use a piece of wood with a notch and a jack to push the shaft up.
I would spend some effort to see what else is wrong, more than gravity is working there.
Can you drill up above and block the bottom to pour babbitt bearing?
edited Sorry I though this was the lower end of the shaft.
Mine has absolutely no play. It is like the shaft and the tube are welded. They aren’t.
Would you be willing to share your files?
Any idea how to remove the the outer tube?
I'm sure its in the manual somewhere
free download
