OEM Wheel Cracked
Newberg, Oregon
Woke up this morning went to the rig and the tire was super low on air. Pumped it up with air and drove to schwabs, come to find out I have a cracked rim on the inside side of the rim. This ever happend to you all? Is it fixable and does anyone have one laying around?
Thanks all!
The OEM wheels are an alloy and not steel, so it ain't gonna be easy to fix.
You could try and find someone to weld on it, but you might just make it worse.
I would look for someone parting out an 80 and see if you can get one of the wheels.
Wheel fixed!!!
So I found a guy here in Oregon who is an expert in repairing wheels! He was able to weld mine and mounted and balanced for $150. Pretty resonable I thought, he has never had one fail and trust the guy!!!. His name is Skip and the name of his shop is . : Skips Wheel Werks - Beaverton, Oregon - 503.641.8001 : . Check them out, tell'em Carlos sent you!
That's an easy fix, any good wheel shop will repair that. Look at mine, as bad as it looks, cracked and bent, is repairable, and can be used safely. A good shop will tell you if is worth the $$ to be repaired Vs. replace it.:beer:
