OEM snorkel template needed
Gilbert, AZ
Finally got my OEM snorkel, but of course there is no template with it. Does anyone have a PDF or copy to pass along?
I have one. I'll try to get it scanned in and put it up somewhere for you to download. It's larger than one piece of paper so you'll have to cut it out and tape it together.
-Trey
Thanks! :beer:
Yeah- it's kind of a pain without a template, isn't it? :)
I already mailed mine to another mudder, sorry.
But, if you have any questions along the way, feel free to ask-!
Doc, did you use any rtv or anything else when installing the snorkel? I'm not sure about those foam gaskets.
No, I did not. I don't plan on being submerged anytime soon. I would suggest some RTV if you know you are going to use the snork.
However- the foam gasket on the intake is at the same height or maybe a bit higher than your distributor, which will also need sealing. So... if you RTV that junction, I'd suggest attacking your dizzy next.
I'd also suggest trying to find a metric drill bit set between now and your install. I think you need the 9 and 11mm bits. I used the closest SAE equivalent, and they worked fine, but I think the metric would have been snugger.
I also put RTV around the A pillar bracket and holes. I didn't trust those to seal to the rain. Water leaking inside your fender is one thing, but inside the headliner is a completely different story.
Good Luck!
If you haven't found it already, check out my install thread:
https://forum.ih8mud.com/80-series-tech/226943-operation-aeration.html
Thanks doc for the files. Your thread from last summer was my inspiration.
Thanks! You should be prepared for the following conversation:
"Hey, what is that THING?"
"What thing?"
"That black THING, on the side of your car.."
"This? Oh, that's a snorkel"
"Snorkel? Like for going under water?"
"Uh, yes. If I feel like it"
"Seriously, what is it.... "
"Snork"
"Wha...?"
"For going under water...."
"No, seriously, what is it?"
"I work for the government, it's a GPS antenna that tracks my location to the nearest meter."
"Why didn't you just say that in the first place?"
"It's top secret, now I have to kill you"
Uh, you're welcome. Like I said on the site, make sure you do not scale or auto-rotate & center when printing those pdf's.
We did use a bit of RTV when doing the install on my truck. Also, we did not have metric drill bits, but if you have air tools it's a trivial matter to widen a hole a bit (particularly for the holes that the plastic clips on the snorkel lock into). Another thing is that we ended up using rivets to affix the brackets to the truck. This was much easier than dealing with nutserts, etc. After cutting a hole in your fender I don't think you'll ever run w/o that snorkel. My antenna was also moved to the LH fender.
I have a few pics of my snorkel install and where the antenna was relocated:
Picasa Web Albums - Trey - FZJ80 lift/tires
ugh i go back and forth, back and forth about this mod... i have the pre-cleaner (it is not technically a snorkle because its not all sealed up right?) and the other pre-cleaner, the one that is bigger and I am just not sure about mounting it.
somedays i think it looks silly and other days i think it looks downright bad ass...
if you wanted to, could you have moved the power antenna over to that side?
I'm not sure as I didn't look into that. My power antenna had busted up internals so that's why I went with the flexible after-market antenna.
My pre-cleaner is, apparently, for a 70 series with the 1FZ-FE engine. If you want a snorkel and can get all the parts then I'd say go for it. So far I'm really happy with it. Although, I haven't done any deep water crossings.
I think if you use a bit of RTV everything will seal really well. It all fits together pretty tight, but I wasn't sure about those foam gaskets so that's why we ran a bead of RTV on the snorkel where it meets with the piece in the fender. We also used some on the elbow inside the fender. It's just much easier to do this when putting it all together. I have yet to remove the pre-cleaner, stuff the top of the tube with something, and listen for leaks around the fender.
Where did you get your 70 series topper?
I bought everything from theferg when he sold his 80.
Ah- Did he give you my chewed up template as well? He had me send my 'used' template to him after I was done with it.
