OEM shocks bottoming out
Delaware
Hey guys, I recently replaced old shocks with OEM. They are bottoming out when loaded with camping gear. Looking for suggestions.
You need heavy duty springs and then torsion bars then, or get airbags
Your springs don't have enough force to suspend the load you are carrying. Have you ever replaced the springs? How much cargo weight are you carrying? Suspension is more complicated than just get stiffer springs, or taller springs, etc, etc. You would need to give a few more details about your rig, how much cargo weight you normally carry, and how much you max carry, so you can get some recommendations that will keep your rig driving ok most of the time, not just when you have the back loaded up with 500 lb of gear.
Hey thanks, for the feedback. I have not replaced the springs. Only recently replaced the shocks, wheels and tires. I was experiencing some fender rub in the front with no load. With the back loaded with family and gear rubbing and bottoming out at every pot hole. Tires are 275 70 18 GYR Wrangler
Wondering if a lift is necessary. Springs, airbags or spacers? I'd like to keep a comfortable ride.
My experience was that my factory rear springs were very worn - they sagged quite a bit, and I also bottomed out with adults in the middle row. The torsion bars had also settled, and when I first put on 275/70R18’s, the top of them were almost level with the top of the fender opening. I decided to replace factory rear springs with OME 2865’s because I was planning on installing a drawer system, but I expect that even just replacing OEM springs would have restored much of the load carrying capacity in the rear. I adjusted the torsion bars to match the rear, and all is well now. Your situation sounds similar.
Yep, needs more spring for sure. To over simplify; springs carry the load, shocks damp and control the motion.
Should be okay in the front with that offset. But you said, "I was experiencing some fender rub in the front with no load." So maybe the front rub was more of a pinch weld/fender liner rub vs fender lip rub. In any case, you need a new suspension kit with a higher load capacity and to address that pinch weld rub... if that is indeed an issue.
I would choose aftermarket, medium load (not OEM) only based on what I can see from the outside. There are low lift, medium load rear springs available but you'll have to call one of the experts for recommendations i.e. Cruiser Outfitters or Slee Off Road
On a previous 100 series, I went with OEM stock shocks and new Old Man Emu springs. Worked well together. Had plenty of clearance for normal use. Mellowed out the harshness of the springs.
If you just installed new OEM shocks I'd say keep them and look at adding aftermarket rear springs based on load/use just like hoser suggests. Then crank the front T-bar for correct ride height (maintining lower front end with some droop travel left), align it and enjoy it.
I recently installed the Timbren Suspension Enhancement System (Front and rear) on my LX470. I added the SES for the benefits of towing and the added weight of SLEE SliderSteps on OEM LC springs.
Happy with the set up so far. No more rear end sag when loaded down, no more front end diving under hard braking, and the SES also helps with body roll.
It did firm up the ride some, but also cushions some of the road cracks and potholes.
Mine are the standard ones, not the soft compound they also make.
