OEM Radio HELP
San Jose, California
Hello All
I'm looking to keep my Landcruiser Stock and I bought a 1997 TLC Head Unit (Anniversary Edition).
But after trying to install I noticed that my male factory plug is missing.
Does anyone have the factory/aftermarket (fourm, ebay and circuit city searches have not produced any result) male plug that might fit into this head unit?
Did your rig have an aftermarket unit?
Usually the installers plug and aftermarket harness into the factory plug rather than hacking the factory harness. Check a little ways up the harness to see if you can unplug the wires that are currently there.....
Do you have a picture of the harness side? The picture below is one of the optional plugs found behind the ashtry, you have to really dig to find the other one but it is the same area. IIRC there are 2 plugs in this set. These were unused in my 96. They contain 12v, ground, dash light/dimmer all the speakers and sub. The EWD details all this.
I could be wrong but I think the harness should have a plug that fits that. I have never looked at the radio itself but when I installed my subtank wiring I used two of the unused optional radio plugs in that are present in the dash. They had the plugs present. I can tell you where to find them. I believe they have all the connections you need. You'd just need to swap out the plugs.
But if not you could buy the plug and pins and make a harness. I can help you with the part numbers if you want.
Dear Cruiser
Thanks for the info and the picture. Given your feedback I'm going off to a wreaking yard to find that plug. I have a feeling that I'll be able to find it on one toyota or another. Thanks again.
