OEM PHH part numbers?
South Jordan, UT
My FZJ80 is in the shop having some radiator work done, thinking I might inquire about having them replace the PHH while it's there. In order to help point them to the right hose(s), can anyone tell me the Toyota part numbers for the PHH?
Thanks.
Ryan
do the bypass. why replace a 2" hose with another one thats a PITA to get to...replace the 2" hose with a 4' hose. say bye bye to that stupid metal tube that connects them, and just have one solid line from the heater valve to the head...2 clamps. from the heater valve, there is the 90* elbow, then metal tube, then the 2" PHH. thats the most rediculous design ever.
1 long heater hose...less is better...
I would argue that a metal pipe is much less susceptible to aging/rotting/bursting than a rubber hose, hence the design (even the heater return line along the PS side of the head changed to an all metal pipe when they did away with the PAIR valve!). It's too bad that in the case of the PHH pipe that Toyota didn't attach the metal pipe directly to the head and avoid the PHH altogether.
When I do mine I will replace the pipe and all. Two clamped end I think are safer then four.
If you go this route, you may want to sleeve/wrap the heater hose. I replaced one on a customer's 80 a few weeks ago that had the pipe replaced with a single piece of hose. The hose chaffed and blew out.
Did it get to close to something hot?
