OEM coil options - 1978 FJ40
FYI: The Yazaki resistor wire, and the BY ignition wires are 10ga, not 8 ga. Besides the battery/starter/ground cables, there are no wires in the USA spec FJ25/40/45 larger than 10ga.
Hi Mark @Coolerman Trying to figure out my options...does it make sense to you to add a Yazaki wire and is that something you can make, since it sounds like it's size and length specific?
Thanks again,
Paul
Quit calling it a Yazaki wire. It's a resistor wire.
The entire harness is made by Yazaki. They are all Yazaki wires.
Do not cut open the harness to install a resistor wire. Just install a resistor.
Thanks so much for replying Jim, @FJ40Jim The dizzy is electronic. The aluminum case igniter I have, only shows for an FJ40....so I should look for a 60 series igniter to match up with the coil you listed 90919-02113
Part 89620-60070 (IGNITER ASSY) was found on the following models:
Date rangeModelFrames/OptionsFound in diagram
08/1980-09/1984TOYOTA LAND CRUISERBJ42,FJ4084-01: SWITCH & RELAY & COMPUTER
Model Dates:Matching Models:Model Options:Links to diagrams:
08/1980-09/1981FJ40L-KJAUSA, TP, 2F, 4F, RB, TPS84-01
08/1980-08/1983FJ40LV-KCJAUSA, VAN, 2F, 4F, VKC, RB84-01
Thanks again for the help!!
The 02113 coil is the correct one for any 81-87 ignitor, regardless of FJ40 or 60. The only difference between the 40 & 60 ignitor is the wire lead for 40 is a little longer.
