SOLD OEM 74+ Rear Step
hyhpe
here
125.00 before shipping. Approximately 15” from hole to hole.
I have a few from very early to early 70's so not picky. Thanks for the heads up
The 9/67-9/73 will work on the earlier one just have to use a nut because the fixed nut is on outer holes. The early one will not work after 9/67 because the bumperettes are moved further in. Not sure if you can tell how wide the early ones are from this picture? These are some goodies I got off a couple of 1963 FJ40s. I got some factory beige bumperettes off the same cruisers.
The 9/67-9/73 will work on the earlier one just have to use a nut because the fixed nut is on outer holes. The early one will not work after 9/67 because the bumperettes are moved further in. Not sure if you can tell how wide the early ones are from this picture? These are some goodies I got off a couple of 1963 FJ40s. I got some factory beige bumperettes off the same cruisers.View attachment 3223780
Thanks Living! Nice collection. Do you know if the beige bumperettes ran through 04/64? I found a light colour (possibly beige but seems more white/grey) hiding under flaking spring green paint on my Australian sourced '64.
I'll take one if you have one. The spacing between the holes is about 14.5" center to center. Thats measured between the inside most holes for the bumperettes.
