Odometer Sticking
Essex, Vermont
My odometer is stuck at 73899, however tenth place moves 1-9. Because I dont want to explain it I'll do an illustration:
73899.0
73899.1
73899.2
73899.3
73899.4
73899.5
73899.6
73899.7
73899.8
73899.9
73899.0
It isn't enough to turn the odometer over to 73900
So I'm guessing the odometer is stuck because the tenths are still moving so odometer isn't broken. My question is should I replace it or take it out and manually turn the odometer over to 73900 or will it just get stuck again at 73999?
Take it out, clean it up. Put it back together and you'll be good to go.
They get 40 years of gunk on them. I know there's some descriptions of the how to clean them up floating around Tech. I think Landpimp did one. I've cleaned up a couple or 3.
Your tenths wheel is probably broken. In mine the wheels got stuck, which managed to break the tab off of the tenths. So now the tenths spins but doesn't increment the next numbers. Just like your situation.
Hopefully yours is just stuck. :cool:
I have spare wheels if that's the case.
Does anyone have a source for a new odometer. My 1970 came without one. I pulled the cluster to see if it had just fallen, but no, nothing but empty space back there.
