Long time wheeler, just picked up a 1994 80 Series. 196k on the clock.
When FORCING the lockup clutch to disengage, I hear a horrid squeal come from somewhere in the front of the vehicle. It almost sounds like the belts on the front of the engine are squaking.
Going into lockup is fine. It's only on forced "unlock". I can hit the brake pedal, forcing it out, or i can crowd the throttle and force it out. Once you "unlock" the converter, you can take it in and out several times before it does it again.
Could this be something as simple as the belts on the engine slipping as the RPMs have to increase rapidly? I can't duplicate the problem any other way other than lockup.
I'm hoping someone else has ran into this before, regardless of the repair.
