Odd Dome Light Behavior
Alpine, UT
My mid-row dome light simply doesn't work. One day it just quit working. The rear works fine--including all door switches. So I took it apart and hooked the volt meter up to the power source in the ceiling, and I'm getting no reading. I checked the dome fuse just in case, and found a 15 amp in there when the specs say it should be 10. Again, the other light works perfectly.
I've tried different bulbs, including an LED from George.
Any suggestions?
One other quick question: has any one found a cool way to wire the map light to the dome light circuit so it comes on when you open the door? That'd be way cool.
TIA.
Any suggestions?
TIA.
I was gonna say the light bulb burned out, but you already covered that :p
I'd start by cleaning the switch contacts. If that doesn't work, look for broken wires or a bad ground...
As far as the map light goes, check out this link: IH8MUD Forums - View Single Post - Light Modifications - For FAQ
Thanks for the response. I took the switch off completely and just checked the power cable for voltage, and I got no reading. So, I'm concluding that power is not arriving to the dome light at all.
Follow the wire back to the main harness, on the driver's side. You'll have to peel the headliner back a bit to get to it. The rear interior light is powered off the same harness, so there's probably a break in the splice point.
My $.002
Here's some pics to help you out. They're from a 91, but I don't think a 94 is much different up there.
Monte, you might check for a bad ground connection at that light fixture. Ohm out the ground point at the fixture to a known good ground point. If your checking for 12v at the fixture and the ground point is bad it will appear to not have the 12v at the fixture.
