Odd Brake Issues
Erie, Co
I bought a 40 a couple of years ago and it had a lot of work already done to it, including a 4 wheel disc brake conversion.
I noticed shortly after buying it, that if I stomp on the brakes like an emergency situation, I get a bit of a feeling almost like ABS for a split second, and the braking is horrible, like only one portion of the master is working. Otherwise if I sort of ease into it like normal I can then stomp and the braking is excellent, comparable to a modern car.
I assumed it was due to something incorrect with the master or the booster, and finally dug into it today. I changed out both the master and booster off of other trucks that are working correctly and the feeling is still there. My assumption at this point is that it must be in the actual discs or after the MC anyway. Anyone had an issue like this?
