- Joined
- Sep 14, 2012
- Threads
- 3
- Messages
- 8
All,
Immediately after the ECU has been reset, either by pulling the EFI fuse or unhooking the battery, does the computer immediately go into "Ready" mode or is there a diagnostic/learning mode it will enter until you drive for several miles? I have the dreaded P0401 code and have made several attempts to fix it, however I am out of time to complete an Emissions test so I can renew my tags. The Emissions station only pulls OBDII codes and tests the gas cap, so if I can have the ECU show in "Ready" mode long enough to get the test done I should be good to go.
I know the resistor trick removes the CEL but puts the computer in limp or not ready mode which will cause the truck to fail the test.
Let me know your thoughts.
J
J
