OBD2 question
South Central PA
I picked up a 2nd 80 series to hopefully turn into a wheeling rig. It's been sitting for a while and needs some love. I bought the OBD2 tool that runs gauges and clears codes too to do some baselining, but when I plug it in ... nothing, nada, zip. The scanner doesn't even turn on. I know it works, because it functions just fine when plugged into my LX450.
The truck was gutted by the PO, which is fine, but not sure if he pulled a wire out of the OBD port or not. This is what the front/rear look like. If anyone has a PIN diagram or a pic of their port from the same year I could compare to I would appreciate it.
I do see a black wire hanging down behind the OBD port. Possibly missing a ground wire?
Google image ... looks fairly different from my PIN locations. :confused:
Um....If you have an LX450, why take a picture of IT and compare? Same thing......
My initial searches showed the some of the pins were model specific, so possibly not the exact layout. I did check the Lex this morning and the top left PIN is in a different location, same as the Google pic.
Check out the data link connector 3....it's the OBDII connector
Pins 2,4,5 and 16 used
