I tried a search under code 71 with not much luck.
I find that nearly impossible to believe since the code 71 is one of the most common we have had over the past 5 years. Try searching for the OBD-II equivalent which is P0401. I think there are a few threads with that keyword. Be sure to limit your search to the 80-Section.
-B-
keywords=code 71*
Works great.
-B-
I didn't know about the * trick.....noted.
It would be great if Google or another search engine allowed that type of search syntax.
-B-
Nice tip Dan. Does Google allow a (keyword1 or keyword2 or keyword3) + 71 ?
The reason that I ask is that some posters use the term CEL and some use the term MIL (as used by Toyota in the FSM.)
Ex: (CEL or MIL or "check engine" +71)
-B-
