o2 sensors - ordered
LCyal8r
Jetty Crue
NEPA
Actually, I guess they are just in my basket waiting for me to pull the trigger. Got the denso front and back for 110 delivered.
234-4157
234-4153
I have a 97 lx.
I'm doing a complete exhaust reinstall. Have all the other parts ready and it occurred to me that I should do the o2s as well when I do the reinstall. My existing exhaust is rotted in a few places.
So, anything else you guys can think of I should be ready for? I'm going to have the parts all installed by a muffler shop.
Good move. Both Denso sensors solved some codes and troubles I was having with my rig. Purrs now...
possibly source some copper 8mm exhaust manifold nuts to use on the sensor attaching studs because if those on your truck have never been off they may be quite corroded.
when I did my sensors last October the nuts were so gone I spent several hours with a dremel carefully grinding them away so as to save the studs. I couldn't find a 8mm nut in any of the shops locally but I found that BMW uses them and my local dealer had them under this p/n-18 30 7 620 549. these and a generous amount of never ceaze and I was good to go.
I'm going to have a muffler shop put it all together for me. Is that something they would have? Forgive my ignorance but are those studs attached to the body or to the exhaust components.
the studs are part of the sensor mount 'bung" that is part of the exhaust pipe[basically a machined metal hole welded into the pipe that allows the sensor to sample the exhaust stream] , 1 precat 1 post cat, and I doubt they would have them but who knows, if they do a lot of euro car exhaust all the way to the manifold they just might.
Ok. I think that'll be fine for my purposes as all that will be new.
So I take it that the Denso part number that LCyal8r used are the ones to buy for my fj80 97.
Need to care of this problem, so I can get my rig to pass inspection.
