O2 Sensor Voltages
Eicca
Professional Noob
Utah
Hey so I need to know how much voltage goes to the O2 sensors and how much comes back out when everything is running good. I'm assuming 12v in and .45v to the ECU when running at optimal O2 levels. Correct me if I'm wrong.
My idea is to temporarily replace the O2 sensors with resistors to force the voltage output to a level that will satisfy the ECU so I can determine if bad O2 sensors are causing my fuel mixture to be too rich. I need to know the correct voltages so I can get the right ohm resistor.
Thanks! I'll let you all know how it goes!
I'm not sure about this, but I think the 2nd O2 sensor is used to compare to the first to see if the cat is working. I think the ECU looks for some form of wave signal and a steady voltage would look wrong to it. But I suppose the worse case would be it would just throw a 0420 code which you could ignore.
Somebody smarter than I can clarify that. Can't help you on the voltages. I suppose you could calculate it from the test resistence in the FSM, but that wouldn't give you the optimal voltage.
Yeah I looked at the FSM... talked about calculating the O2 Sensor heater resistance and making sure they're sending voltages but not about if they're sending the right voltages.
It's also used for long term fuel trim, and a few other things.
Actually I take back what I said, that would only apply to an OBD-II truck. Eicca has an ODB-I truck, so no O2 sensors after the cats.
Right. Two sensors, one on each branch of the Y-pipe going into the converter. Now howzabout them voltages? :)
