O2 sensor replacement
Maine
What the hay do you use to get the gasket off? I tried flat razor but the old gasket was crispy and some portions wouldn't come off. Bought gasket remover and that didn't penetrate well enough. What a bitch to get off. Especially laying on the ground in sub freezing temps with no car ramps. I just plain didn't fit under there. Buying ramps tomorrow! I plan to dedicate an old plain iron for upcoming gasket removal. Any other tips? Thanks!
I did the same thing..took me 8 hours to remove both sensors and gaskets. Nuts were beyond rusty and could get bolt out to work properly. Fortunately, the gaskets pryed off with a flat head screw driver.
Dave
The nuts were all but gone on mine too but they came off reasonably easy. The gasket was fried to the pipe though.
makes me appreciate SoCal weather a lot more....sorry to hear these horror stories....my two O2 sensor experiences were very easy....I guess you don't have to pay the insane cost of living expenses that I do though!
Good Luck,
Smit
for me the gaskets came off in one piece by hand.
I h8salt,
Mine were fused to the pipe. I stuffed a shop towel in the hole and got after it with a wood chisel – it actually worked best to use it “sideways” to scrape it off. Don’t forget to wear gloves or you will need a tetanus shot afterwards.
