O2 sensor question.
Northeast Ct
Hey, had a check engine light for the upstream O2 sensor. Bought a denso sending. When I went to plug it in, the pigtail of the connector was cut off.
So now I have to do the same, but not sure what color wires is to put the what color wires.
The denso has
2 black
1 white
1 blue.
Stock harness has
1 grey
1 blue which might be shielded
1 yellow w/ red stripe
1 brown w/ black stripe.
You need to specify the model year of your vehicle. The following thread should help.
So wired the O2 sensor yesterday. Took it for a drive today, after clearing the the check engine light code.
After about 10 minutes of driving light came back on.
This time check the code and it reads po125.
No, the O2 sensor had the plug, but my wiring harness o2 sensor pigtail is missing.
Even though it's a different code, then the original O2 sensor code. I imagine it still has to do with the O2.
I was pulling on the harness to gain a little more slack to wire everything together.
Hope something didn't break within the harness (brittle maybe).
