No, they are not the same. The first five numbers for each are the same: 89465 but the second numbers are different: upstream and downstream do different things which is why they have different numbers. The downstream one is partially a redundant O2 sensor that makes sure the first one is doing its job correctly while the first one sends most of the important engine management system information to the ECU for correct engine operating parameters.
As in all Toyota part numbers, the first 5 numbers tell you the component system you are dealing with: engine/powertrain/chasis/electrical/body etc. The second set of 5 numbers indicate vehicle model as well as supersession information for different part generations, as well as differentiations in things like measurement/generation of vehicle/universality.
You need two separate O2 sensors to correctly change them out for a mid-1995 to 1997 OBD II compliant vehicle.
