NP203 to 16 spline doubler kit
Status
Not open for further replies.
Knee deep in hookers and gin
I'm looking to upgrade to a split case and these parts won't work.
NP203 adapter plate, bearing and output shaft for mounting a NP203 Gear reduction box between a motor and 16 spline (4 speed) transfer case. Adds about 8 inches of length. Gives you the choice of 1:1, 2:1 and 4:1 with a stock transfer case.
It will also work with an Orion or Inchworm 16 spline case. If you put it with a 4:1 Orion you will end up with 1:1, 2:1, 4:1, and 8:1 options.
Works best in a wagon, but will work in a 40 if you take care to work with your driveline length.
Located in Chicago area. 60565
I've run it for a year or so and I love it.
$400 or best.
I'm keeping the 203. I'd like to buy a split case adapter to put a split case behind the 203. It is currently behind a TH400.
I'm selling the adapter plate, the output bearing and the output shaft. All the stuff that comes from AA when you order the kit from them.
Status
