Voltage indicator tuned on along with most other indicators at the same time. Car was working fine but now it will not start. It turns over fine and sputters some times. I did get it to start once but it died after 30 seconds... The distributor kept clicking tho... Till I pulled the key.. Any ideas?
Is your battery dead? Have you tried to jump start?
Not sure what you mean by "The distributor kept clicking tho... Till I pulled the key."
The distributor doesn't drive anything and doesn't really have anything that should "click". Are you actually meaning a different part? Do you mean the starter?
The clicking sounds like it is coming from around the distributor.... Not sure what it is.. But when the key is in "on" position it just starts clicking. Also I just noticed that the rim needle is wiggling.
Batter is not charging for some reason and is low... But with a stater battery it still will not start.. Turns over fine... Starter spray did not work.
I'm going to have to think about this one a bit. I have not heard any clicking like that before. Possibly fuel injectors trying to fire? Fuel Pressure Relay? It is affecting the tachometer, so it appears to be ignition related rather than fuel. @Tools R Us ? @inkpot ? @scottryana ? @NLXTACY ?
if it helps... when I pull the EFI relay the clicking stops.. it is almost like the car thinks the engine is running.. and it holds that relay open as soon as you put the key in "on". What is supposed to trigger that relay? I felt it and it was not clicking during the clicking sound.. if the it is ON when the key is "on" not "ACC" what other condition is supposed to be met before it comes on. I am thinking a grounding issue..
I already tried a new EFI relay and it does the same thing... it "closes" when the key is "ON"
I was looking at the wiring diagram, the only way I can see that relay being provided power to close is the output marked "MREL" on the ECU. It is obviously getting a ground cause it works when we turn the key... the only thin I can think of is the way the Ignition switch works, it looks like the ignition switch also feeds from the switch AM2-IG2 to IGF & IGT on the ECU. perhaps those are not getting power?? or something like that.. the TACH also feeds off that line..
WELL fixed. It turns out it was a short in the wiring going to the Alternator. It actually melted the post, now I gotta replace the that.. yay.. at least it is solved!! a common problem?
