Hi all.
Im about 5 hours into a fan belt change that made me decide to fix a few leaks around the valve cover and distributor, I have all the parts back together but now the vehicle wont run more than 200RPM's pushing the throttle has no effect.
I removed the battery, Could the computer be trying to get back to normal, Like when you pull the EFI fuse? The distributor rolled off the box I set it on, Only a 2 foot drop, Could this have anything to do with it, Ive found TDC and the rotor was pointing up more or less, But I cant get it to run well enough to see where I stand on timing, Let alone how I should have the timing set, 0 deg, advance/retard...
Im stumped and pissed off...
Any thoughts?
Any thoughts?
