Normal temp/oil gauge levels?
Lebanon
My temperature gauge doesn’t rise above this mark but takes a few minutes to reach it when cold, and the oil pressure almost goes up to just before the high limit, is it normal?
It’s a Gulf spec cruiser if it makes any difference (middle east), did they have different sized radiators, if anyone knows. Or is my gauge shot.
Mine goes to exactly horizontal and it is that point at -5F and 95F ambient. My oil pressure changes with load but at 2500rpm on the highway, it is slightly higher than that shown in your photo.
You may want to look into RavenTai temp mod. I believe its in the FAQ. As for the oil, that is about where mine is at.
I would look into replacing the thermostat or making sure there is a gasket on top of thermostat (if it is like the 3fe thermostat) before I did any temp gauge modification. No need to start doing the fancy temperature gauge tweaking yet.
Oil pressure sound normal.
What engine?
-B-
Our temp sits half way,after two oil gauges that both read ext. low I check the oil,the gauge I dont pay much attention too. Mike
My temp gauge sits dead center. I had bad fuel economy, than noticed some irregular temp gauge readings, so i changed the thermostate and cap, and the temp gauge raised just slightly to dead center, my gas milage went up, and I was happy. Something is definitly wrong with your temp reading, I think they were all designed to sit about center, but i could be wrong. I'll lay some money down on this one though:hhmm:
I don't have OBD connection on my truck, no computer of any sort on it it's a '92 carbed 1fz-f, so i am not sure how to go about doing the resistors, or getting a real reading of the water temp other than physically opening it and taking it.
i changed the thermostat about 9 month ago, and the temp didnt' move it always resided in that region plus or minus a needle when hot, even when fully loaded and tires deflated going on trails.
on another note, i read that there is a special way to install the thermostat at 12 o'clock, if it makes a difference it was 85 Celsius = 185 F oem unit. not sure if it was at 12 position though.
Don't worry about it.
I believe yours has a cast iron head and being a carb'ed engine with no ECM it probably uses a different temp sender and gauge than those here in the US with the 1FZ-FE.
You'll be fine.
-B-
