Hi all, I inherited an unfinished fj40 project from my wife's uncle. It is apparently a 1977 frame with a supposedly rebuilt 350 dropped in. It has an unpainted fiberglass tub on it. There is also a set of painted fiberglass front fenders. All the rest of the body parts are metal and are painted and look to be in top notch shape. There is also what looks to be a new top. In addition there are a lot of parts that should be close to enough to finish the project including seats that are in perfect condition. The problems I have run into is that the motor was rebuilt and never run. Every cylinder failed a leak down test. So the motor is probably junk. Second is after doing research in the forums, I think the tub is not worth going forward with either. So I'm on the fence about even bothering trying to finish the project unless I can find a better tub. After a quick search I found a 1962 on Craigslist. He was told it was a fj25 soft top version. Would this tub fit a 1977 frame? Any advice would be appreciated, thanks
