Noob question - Rad. Hose replacement
Vermont
I'm tracking down a leak and went to change the radiator hose on the top right side, facing the engine. When I remove it coolant pours out and I have to frantically put the hose back on. How do I prevent/deal with this w/o draining the radiator?
I don't think there is a way w/o losing coolant. I'd just drain the coolant from the rad. If the coolant is fairly new, filter it before putting it back into the rad.
no need to fully drain the radiator, just a couple of quarts should bring the level down enough to remove the upper radiator hose without spilling much coolant. You can aid this by parking the truck uphill.
after doing this hose replacement, you'll need to "burp" the system. fill radiator, then look at the top/rear of the engine (actually above the engine on the firewall), you'll see a heater hose and heater valve. Disconnect a hose and then add coolant there (funnel) until filled, re-connect. (do this with the heater valve open [heater control set to red or hot]). You can aid this process by parking the rig facing downhill (to bring any air bubble to the rear)
Afterwards, drive it around, make sure the heater works.
Then check the level (at the radiator cap) next day when cold, and parked on level ground. Top up as necessary.
amazing. just what i was looking for. thank you
where is the drain on the radiator?
the drain plug is on the bottom of the radiator.
Upon reflection, keep the rig level when draining some coolant If you park it uphill as I originally suggested, more coolant will flow toward the engine, where you'll be removing the hose!
But the downhill suggestion while burping is valid. After filling as much as possible at the radiator, put the cap back on the radiator, move it to face downhill, then fill at the heater valve area.
i'm going to have to drive to a downhill location. after filling the heating valve how long should i wait?
Probably best to skip that then. Driving it will start to heat the water and build pressure. Just fill it best you can on the level, then drive, and check the next couple days, cold and level, (at the cap, not the overflow bottle).
Another suggestion: It's a landcruiser! You could back onto a couple of parking bumpers or the curb, if available.
:D
I've done this in my driveway (level) and just jacked up the rear of the vehicle.
Don't worry about it, it just makes it more efficient to get rid of the bubble this way, but it's not essential.
good luck!
yea i'll just jack it up, can't believe i didn't think of that.
again - thank you
