Noisy power steering pump
Arizona
what could cause a power steering pump to make a noise that sounds like i have a diesel swap?
My buddy(diesel mech) pulled my old leaky one out and replaced with a new one, reusing the gear while i fabbed up my bumper.
Well, i thought it was a bad pump, so i bought another and it nakes noise. Could he have bent or damaged the gear that I wouldn’t have noticed when i swapped pumps? Its the only part that swapped with the pump changes. It did NOT make noise before just leaked badly.
How was the gear held to loosen/tighten the nut? Most that we have seen were dorked teeth from that process. Have been able to recover them by carefully removing the high spots.
THAT is the question.
Ill have to remove and look at it all. Im thinking he used my vise, so that for sure would have done it. Iirc, I looked at the teeth and could see slight marring, but thought it was really minor.
I used a screw driver and allowed it to bite onto it camming it into the vise, so the teeth ONLY touched plastic.
So, since this seems like my issue, where do i get a new one or a good used one or should i bust out the jewler files and try to clean the teeth up?
Well, quiet as a church mouse, now. Jewlers files and 15 minutes of my time(filing) plus yanking the pump and putting her back.
For guys who want to say they have a diesel swap, but don’t want all the headaches of actually doing a swap and paying for it, can just ding up the gear and bam!!! Diesel swap on the cheap! Just don’t forget To keep using regular gas.
BTDT. The gear is easily damaged when swapping in a new pump.
Glad you got it squared away.
Yeah, its pretty soft. File was easy work and it was a beat to s*** old one I’ve had for 30 years. If it had been dropped on concrete, I’d need a new pump gear. Pretty soft!!!
