Noise upon deceleration... differential problem?
I ruined my front diff earlier this year, and your symptoms sound identical to mine.
Mine started whirring 1000+ miles from home. The next day I topped off the front diff and it took about 1 quart of oil, so it was very low. Drove it home RWD with the front driveshaft removed. The bearings and gears were toast, so I bought a press and rebuilt it.
Was your noise one that could easily assumed to be tire noise (not metallic) that began around 20-25MPH and disappeared at highway speed? Kind of a ghostly low frequency whoohwhoowhooh in the cabin that you really only hear with windows up?
The main difference is that tire noise would happen in any load condition (accelerating / decelerating / neutral).
The noise that I experienced was only audible when accelerating or decelerating. If I applied just a little throttle (to take the load out of the drivetrain) the noise would go away.
Mine turned out to be toaster front diff, also. Exact same symptoms as yours. Thanks OP for all the diagnostics and video…large cost to replace, but saved me a lot of time and frustration of throwing parts at a terribly annoying woowoowoowoo noise .
UPDATE: dealer that diagnosed my noise as bad diff, came back and said not diff- tire noise. I swapped a new set of less aggressive AT tires (Yokohama), and the noise is almost gone.
