82 4x4 pickup.
Have a noise that is a cross between grinding and rattling when
coasting
driving under power
2wd with hubs in 4x2
steer hard to the right when hard turning left to right back and forth
Was not felt through either shifter or through pedals.
Had recently rebuilt the knuckles so I tore into one side and found the thrust washer had a spot rubbed into it from the bearing cup rolling against it. Redid preload and buttoned it back up. While I was dinking around I locked the passenger side hub. Forgot about it and drove to work the next day...no noise. Went to drive to work next day and remembered I had locked the hub while working drivers side bearing and unlocked it. Started out down the road and my grinding noise was back...did not link hubs locked\unlocked to noise till tonight.
Tonight I come home, lock hubs and go for a test drive. No noise. During test drive I went back and forth between 4x4 and 4x2 and got consistent results. Noise goes away when locked in 4x4 running in 2wd.
Thought I could toss this out there and by the time I wake up maybe someone has some time saver suggestions.
coasting
driving under power
