- Joined
- Jun 11, 2003
- Threads
- 170
- Messages
- 711
Ok, so I walked past my parent's parked 2011 GX460 the other night and heard a humming sound coming from the underside rear of the vehicle, behind the rear wheels. Vehicle was parked and had been turned off for several hours and key was in the house, not the vehicle. There sound reminded me of a running fuel pump or an antenna motor. Anyway, I pulled all of the fuel pump related fuses and relays and sound continues. Finally I pulled a large white fuse from the under hind fuse box labeled "Noise Filter" and the humming sound immediately stopped. The noise did not start again when I put the fuse back in its place.
So has anyone else experienced this? What exactly is the "noise filter" and is this normal behavior or is there an issue that needs to be addressed?
I'm concerned that whatever was running could at the very least drain the battery leaving them stuck somewhere...
Thoughts?
Thoughts?
