no window spray
hiya folks the 94 80 wont squirt wiper fluid on the window, i tried cleaning the nozzles out with a paper clip, i bought the rig last week, the reservoir was dry, filled it up, still nothing, its a constant 10 degrees here in montana, however i hear no mot:beer:er turning when i engage the wiper fluid, any thoughts thanks ryan
Pull the washer fluid tube off the squirters and see if the pump is a'pumpin. If it's good, I read in another thread here that squirters from a Highlander will direct fit, and have a 3-spray pattern. If she no pumpin', time for a new pump.
10 degrees is only an issue if you're using warm weather windshield washer fluid, I would think. But then you'd know it as it would be frozen in your tank as well. Work back towards your pump to check the lines, or start at the pump and work towards the squirters. Process of elimination works best.
Dan.
Dan.
The tanks would not necessarily be frozen for the temperature to freeze the pump and/or nozzles. I've seen this quite a few times when I would venture North to colder areas. If the washer starts to work after leaving the truck in the sun for a while (helps more if you have a hot engine), then it's frozen fluid. Drain the tank, put -35* fluid in, and run it thru the lines.
