No Start (checked fuses)
i know this sounds like a simple question...
The car doesn't crank over!
the battery is fine, the accessories are fine. i've checked all the fuses in the engine bay as well as the fuse box under the steering wheel. they all seem fine.
this happened right after a hard heavy rain... luckily i parked it and i tried to restart the car and hasn't since then.
this has done so before when i went through the car wash... so i think it's some wiring shortening out??? last time, the IGNITION (ECU) fuse blew (in the engine bay) and it pretty much melted that part of the fuse box...
but this time, i checked that fuse and it's okay!
i'm very confused now... is it the starter not getting juice? any help would be greatly appreciated!
thanks
Doesn't sound good. Pictures of the fuse box?? Did you replace the fuse box? My first guess wound be a loss of connection in the melted portion of the fuse box. Even if you get power again, your problem most likely hasn't gone away. It sounds like your in for a ride trying to chase down the root cause of the short. I don't know offhand what wires are involved in the IGN(ECU) circuit.
GOODLUCK!
