No Spark
Corpus Christi, Texas
My 97 Land Cruiser died on the road yesterday and sitting in a Wataburger parking lot. Will check it out this morning.
1. Turns Over
2. No Spark
3. When key is turned on CHECK ENGINE LIGHT does not come on
4. Will not shift out of park with key on and foot on brake (plan to check neutral switch)
Also the orange light above the volt meter came on for about 10 miles before car died it still shows when the key is turned. No sure if related to the no spark problem
Battery is still strong enough to spin motor fast but jumped it also to be sure it was not the problem
Thank you for the help
Check your fusible links and fuse to the ECU. With no CEL in key on, the ECU does not have power or is broken. With no ECU, there will be no spark and no fuel, so you must start there.
