No Spark - It's Contagious
Beaverton, Oregon
I think I'm on the right track with this, but wanted to post up to make sure.
1974 FJ40 that has been sitting in a mouse-feces-cocoon for 25 years. Tried starting it up for the first time tonight. Carb has plenty of gas. Air cleaner off to see what's happening with the carb. Engine cranks, but won't start. I pulled the HT wire from the coil off at the distributor and held to the block while trying to start—no spark.
Here is what I've tested:
Multimeter + : Coil +
Multimeter – : Battery –
Coil – : hooked up
____________________
= 11.89V
Coil – : grounded
= 5.34V
Mult. + : Ext. Resistor BL/YEL side
Multimeter – : Coil –
Coil – : grounded
= 11.09V
Mult. + : Ext. Resistor RED side
Coil – : grounded
= 5.49V
Coil Tests:
1° Coil Resistance: 1.6Ω
2° Coil Resistance: No reading. Multimeter doesn't move off the 1___.__ initial reading, as if nothing was connected.
External Resistor Resistance: 2.1Ω
Spare External Resistor Resistance: 2.1Ω
I'm thinking the coil is dead, since the 2° resistance doesn't even read anything. I'm a little concerned the ignition voltage to the coil is low at 5.34V. I've cleaned up the ignition wires and checked the connection in the steering column, cleaned up all the grounds and connections I could see, and wiggled wires while taking readings. Nothing seems to change things.
Thoughts?
No ignitor on my '74, but the case ground for the coil probably does need help. Looks like the original coil mounting bracket was welded on. The welds broke and it is just screwed into the fender an inch or so over from the original spot. There is a little surface rust underneath. I'll clean that up and re-weld the bracket to clean metal tonight.
As I think about this more, I don't think the coil case ground issue would affect the secondary coil resistance. I'll have to play with the multimeter some more and see if I can get any reading at all at different settings, but I would think checking resistance/impedance through the positive coil post and the inside of the coil output should show something even in hand with no vehicle ground. The fact that I'm getting no reading at all leads me to think I have a defective open-loop situation in the secondary coil. Heading to Napa for a cheap coil after work to test things after I clean up the ground situation.
Yep. External resistor. I actually read that thread last night. Good read and thanks for the link.
I think my resistor is ok. I have two—one on the truck and an old spare. Both show a resistance of 2.1Ω. Higher than the 1.3-1.7Ω range shown on that other thread, but since both are exactly the same, I'm guessing it's just because my resistor is a little different than the one pictured. And, the available voltage on the front end of the resistor is near 12V, and there is a drop over the resistor to about 5V. Lower than it should be, so maybe the 2.1Ω resistor is too much, or maybe my initial voltage is too low due to crusty connectors and bad grounds. Still chasing those gremlins.
I didn't follow all your charts, but I would suggest making sure the points go shorted to ground when closed, and infinite resistance when open and disconnected from the coil. Second, when you measure the resistance of the secondary coil circuit, what range are you setting the ohm meter on? Put it in the 20K ohm range and read the resistance between the coil tower and the positive terminal.
Date night with the lady. Not much progress.
Like an idiot, I forgot to change the range on the multimeter yesterday. Good catch, Doug. I figured that out lying in bed last night and tested it first thing when I got home today. Meant to do it before work, but was running late. Retested the secondary coil resistance on the old coil with the meter set to the 20K setting and my old coil measured 11,700Ω.
Sorry if my shorthand was confusing. I typed it five different ways and the plusses and minuses all looked weird. Is this better?
Multimeter POS connected to Coil POS
Multimeter NEG connected to Battery NEG
Coil NEG hooked up like normal
This setup = 11.89V
Coil NEG grounded to Batter NEG post
This setup = 5.34V
Multimeter POS connected to External Resistor BL/YEL side
Multimeter NEG connected to Coil NEG
This setup = 11.09V
Multimeter POS connected to External Resistor RED side
This setup = 5.49V
Coil Tests:
2° Coil Resistance: 11,700Ω
So... bought a new coil at Napa on the way home. Still no dice. The coil output wire doesn't really fit right and it doesn't fit the OEM mounting bracket. When I got it hooked up and finally got the output wire shoved in there, I was able to get a spark from the coil wire held close to the block when I removed the ground from the Coil NEG post. I wasn't getting that on the old coil, but but it still won't start.
One thing I did notice was that the external resistor was getting damn hot. I mean, I could smell it and feel the heat coming off it. Too hot to touch. That could be bad, or just a result of me cranking too long trying to get it to start. Everything looks ok when I removed it.
I cleaned up the broken coil bracket mount and will try to re-weld it tomorrow if I have time. We'll see if I get better voltage to the coil if I have a better ground. I've checked every other connector I can get to. Everything looks clean enough to get a good contact. Still a little concerned that the incoming voltage to the coil is a little low. Too much resistance in the external resistor?
I welded the mount back onto the fender after grinding to fresh, clean metal. Then, bolted everything else back up after ensuring clean contacts and grounds.
Got spark from the old coil, so looked at the distributor. Looked ok from the outside, it pulled the points to really check them out. They appeared to be opening, but they were so crusty, I don’t think they were and probably not letting the coil charge up all the way.
After cleaning/filing the points and setting the gap properly, spark was WAY better. Uttoned it all back up and it started on the first try. 25 years, and she fired right up and ran like a champ.
Thanks, all, for the help.
