no oil pressure
well it was weird, the gauge has been working fine, it just decided to quit when i merged onto the highway, so i sweated bullets til the next exit, hit up a gas station, checked the oil and everything, all good. so i started it back up, knowing that if i really had no oil pressure i'd be hearing it and feeling it. the oil pressure needle rose to it's usual spot, then after a minute or two dropped to zero. but the engine ran fine, nice and smooth. so i just continued driving. i'll be checking my connection.
You'd be seeing your temp guage rise...or is it not working either?
Had sort of the same issue a little while back.
Put in a mechanical gauge and be done with the electrical gremlins. Another plus is you get acutal pressures, not just H or L.
I thought the wire fell off my first Cruiser...I was wrong. You'll know it didn't fall off when you see the rod sticking out the side of the block :D
My dad was troubleshooting the oil gauge the other day on his 79. I learned a few cool things. For one, it is the heater fuse that runs the gauges. Not sure if the gauge is working, ground it out and the gauge should sweep to high. Feeling simple, pull the sending unit and fire it up. If oil sprays out the hole, you have oil pressure.
metalonmetal said:
logically, is it possible to drive a stock 2f motor 50 kms without oil pressure?
Just put some PROLONG in it and call it good ;) .... actually no motor regardless of type will survive for long with no oil pressure!:doh: Are you running an electric or mechanical oil pressure gauge? If it is electric, I would definitely have the sending unit tested or go with a mechanical gauge...
