95' tlc. 210k, swapped non locking axles for oem lockers. My first issue was using a 94' donor main sill harness. I wasn't getting the shift lock mechanism to release. That eneded up being a rotten connector where the ground spliced with two other grounds. Easy fix once we figured it out. the other issue was the abs light was on. 4 pin outs to the abs module? had to be moved over one spot. I still don't have the 2nd start or power function due to lack of plug on the 94' harness.
my current issue is a combo of disfunctional cdl position switch(already ordered a new one) and lack of illumination for front and rear indicators on the dash. I installed a dash cdl(hazard) switch. it does not turn on the cdl in high gear. I jumpered the cdl position switch at the transfer case giving abs and center diff lights. Turning the locker dial yields no flashing or solid lights. I can hear both front and rear actuators moving. jacking up one wheel at either end the front is confirmed locked the rear is not. any idea why I get no dash indicators, even blinking?
