no horn, radio or flashers...
southeast wisconsin
what are the possible causes for a the horn radio and falshers that dont work on a 87 runner.... the fuse under the hood is good, and the fuse on the radio is also good... suggestions please on where to look!!! ill take any except to check the fuse... ill take replace the fuse but not to check it...:confused:
Horn and flasher fuse is under the hood behind the battery. Neither should be affecting the radio, so that is another problem. Pull the radio out and check the main power wire.
actually the radio is tied into the horn fuse... i didnt know that till my horn stopped workin along with my radio... replaced the fuse both worked... but this time i checked the fuse and it was fine... but i will check once more just to be sure
i have a stupid look on my face... the metal fuse holder thingy that the fuse plugs into actually came loose so it stopped making cantact with the fuse and thus killing power to all three... i have the biggest stupid look on my face
