No Heat!
Central Oregon
The other day the heater on my 92 suddenly stopped putting out warm or hot air. Blower is powerful in all positions. If I'm stopped for awhile or in traffic it will feel slightly warm. I searched and did the related troubleshooting per the FSM and still no heat. No strange smells and I don't suspect a rodent in there. The factory temp gauge reads normal and everything else seems fine. Also, the rear heat works perfect and has been a lifesaver so far. Could the main heater core plug up so suddenly? Anybody had any experiences like this? Thanks in advance for any leads!
Not entirely sure if your heater ciruit is set-up same as my 96. Coolant level OK, all hoses OK, cable to heater valve working and connected correctly, "burped" the system, thermostat working, heater hoses feel hot to the touch ???
I used to have interminent heat last winter, and discovered that my HG had failed.
Everything seems to be in order except for the lack of heat coming out of the vents. I was suspect of the water valve but it is hooked up right and appears to be operating properly. I did check out the relay and it was OK. I guess the next step is going to be to tear into the heater assembly to get to the bottom of this.
Thx,
Randy
Same problem as you - weird (rear heater works and sporadic heat from the front)
To get heat back - move the slider to the center (wait a sec) and slowly move it to the heat range until you get heat - after that don't touch it ever again ...
I'm told but I haven;t had the chance to take the HVAC apart. I'm told a soleniod motor failed - there are 3 soleniods as I recall from looking at the FSM on the blower.
On the 91 I wrecked the problem was a clogged heater core. I took the lines off at the firewall right by the water valve and hosed everything out. I took about 5 minutes to clear it all up. I alternated between the inlet and outlet sides, and cleaned the valve. That was some of the nastiest water I'd ever seen.
Now I have the same problem with it's replacement, another 91. Any guesses as to what I'll be doing today? Just got (somewhat) cold here.
PROBLEM SOLVED! Finally got a chance to flush the heater core out today. Followed your suggestion TX Cruiser! Thanks! Some nasty crap came out of that thing. Also, the water valve was crudded up big time. It was opening and closing but the deposits inside had clogged the opening. After putting things back together I head out for a test drive and the heat was as good as new. I had flushed the system about 18 mos ago and have never had a cooling / heating problem and my rad is in good shape. After seeing the junk that came out of my core I'm going to flush the whole thing again in the spring when it is warmer.
