No Headlights, Tailights, Running Lights
NEW: More Trouble Shooting Questions: No Headlights, Tailights, Running Lights
DROP to Bottom of Thread for NEW Trouble Shooting Questions
OK -- I give up - 4th of July jinx
No headlights, taillights or running lights.
Hooked uo the boat and lights --- tested the lights (light switch was "on" when I plugged in the boat lights). Signals worked but no head, tail or running lights. Brake lights work.
Disconnected boat connection: no head, tail or running lights. I have turn signals and brakes.
NO fuses are blown -- have gone through all the fuses in the fuse box in the car and the fuse box in the engine compartment. NONE are blown including Head (LH and RH). There is a "HEAD" relay in the engine compartment fuse box. Anyway to test it? I have unplugged and reconnected it with no affect.
Do not know if the boat had anythng to do with it (it has been disconnected and lights do not respond). Have not driven in a while.
Any ideas --- what am I missing?
I have not yet disconnected the battery.
break out the VOM and really check those fuses?
I've fought similar before that turned out to be a fuse that LOOKED good but tested open:doh:
that was a long day for a simple check I could have done first.
Will do ---
However --- should they all go? head, tail and running? Head has two fuses (one for each light --- is that correct?)
Thanks
think so, looked on P.173 of owners manual, check fusible links if lights are out and fuses good, use only fusible link to replace as plain wire will allow harness damage; paraphrasing there, but you get the idea. picture shows two short sections right at the battery box where the cable goes through.
good luck, happy 4th:beer:
Thanks
Tried to look tonight but too dark -- will pick it up in the morning
Have you ever had one go on you? Wonder if it was my trailer lights. Checked manual and says to only replace with Toyota fusible link -- kind of blows the night driving on the weekend since nobody will be open if that is the problem.
Will check in tomorrow
OK -- back to basics
1993 Landcruiser
Checked continuityon fusible link --- it is good
Checked continuity on the fuses -- all good
Headlight Relay
1. Are the headlights, running lights, tail lights supposed to come on if the switch is on w/o the key?
2. Are the above supposed to come only with the key
3. Does the headlight relay control all three of these (head, tail, running)
The headlight relay --- should I get a "clicking" sound when I turn the Key on and/or when I turn the light switch on --- I do not get a click currently --- is it the switch or the relay.
How do I test to determine if it is good or not --- new at Schucks is $60.
After pulling th relay, I get power to the two slots towards the battery (no power to the two slots towards the driver). Power is constant with or w/o the key "on" (testing is done w/o engine running -- but when engine is running , no lights)
OK guys --- tell me how yours is working so I can better diagnos this beast.
I'm also '93 owner, Ill go look and post back pronto
yup, power all the time, so you can better run your batt dead when your anemic buzzer does not remind you to turn them off:flipoff2:
my relay audibly clicks and lights come on w/ no key, a standard relay would work if you have one laying around, I have a couple here in the garage and some spade type terminals so four short wires and viola, :cheers: headlights for nuttin.
can you take a relay out of the '55?
$60:eek: for a relay is outrageous, and if you just need to get to the lake for the weekend you can make do with a borrowed part till you can get to the pick-a-part near you:meh:
Thanks for the help in diagnosis
Must have fried the relay when I plugged in the trailer lights -(lights might have been on) -- you think you would have blown a fuse first if I was shorting somethin out.
Yep -- Schucks is $60. I called Toyota first but Parts is closed till Monday. I will probably let is sit for the weekend or not drive it at night.
Does the relay control all three -- head, tail and running?
Where is Roseburg, OR --- I am in Richland WA
Also, had a house fire (smoked out) so the 55 is at the house --- I will see if I can find the relay to see if it is the same --
Otherwise, you are confident I can "jumper" the relay -- is it just two wires to make the connection from "hot" on battery side to cold on driver side and then another for the hot to cold connection? four slots, two hot and two cold (jumper them together with one wire each???????)
Thanks
1. Yes- IF you turn on the switch without the key.
2. No, see #1
3. headlight relay controls headlights only. There is a separate taillight relay in the DS kick panel.
These trucks have a cool feature with the headlight switch. You can leave the switch on with the key, turn the key off, and the headlights will turn off. Many here drive like that. But, you can also turn on the headlights without the key, like normal.
Yes. with the engine off, it should be a fairly audible click, coming from underneath the hood.
I agree, $60 for a relay is outrageous. My guess is that since neither head- or taillights come on, there is a problem with the switch itself or the headlight control module.
Do you have a Factory Service Manual??
AFAIK, there should be power to at least one of those terminals. The two terminals you mentioned that did not have power, those are from the switch. If the switch is ON, there should be power to those terminals, and no power if the switch is OFF.
I have a 91, so no headlight control module here. But everything else is the same. I recently had to replace my switch because of an electrical error I made. Symptoms were similar to yours.
HTH
-Lane
south of Eugene 70 miles or so, or three hours south of Portland. sounds like you ought to repair the wiring on the trailer before next attempt, I have a little tilt bed trailer that popped fuses all the time on the company rig (05 chev 2500HD), traced it out to a bad ground jumper from tongue half to bed half:mad: after most of a day trying to find the fuses in the work rig, and the one that looked good was not.
good 4th to you, careful up there with the good firecrackers. I have family and friends up that way; Kent, Mukilteo, B-ham. good memories of bottle rocket wars with the cousins:hillbilly::beer:
I' d have to probe the fuse block to see what does what with the switch, DO NOT JUMPER IT!! may repeat your house fire problem! :whoops:
my idea was to take a relay and mimic the function of the toyota part without it having to be a toyota part by tapping into the fuse block with male spade terminals, a short quartet of wires, and female terminals at the generic relay.
bandaid, but a pretty good one.
OK - no factory manual ---
The Key on and off option I thought to be the case (goes off with the key) but could not remember -- not a daily driver (gas prices, have a 40 and 55 too, along with Avalon, camry, Isuzu Pickup - you get the picture)
OK -- Sounds more like the switch since not getting power at the HEAD relay slots. But could be the headlight module (where is it located) ---
Where is the tailight relay?????
I will test again this weekend to verify --- this house fire has been a pain in the butt since I keep having to run back to the house for tools and diagnosis.
cool trick about the light switch on/ key off-off, thanks LKa1988
Yep need to check out the trailer --- used adapter to go from round pin stock to 4 prong --- has worked in the past. Maybe it is the switch or module (see Lane's response) and this is coincidental with the trailer:bang:
Got some good stuff for the 4th to blow up.
Have a good 4th
Thanks
Tblume and LKA1988
Thanks both for the insight --- we will see how dangerous I can be with it. Noticed I "asked" before "jumpering" the relay --- I have a electrical phobia --- and don't need to burn up the truck like the house (dryer fire --- electric motor that was 4 year old). Insurance company is working with the manufacturer to resolve.
Lka1988
Do you remember how much the switch was? This might solve two problems I have:
1. Lights -everybody has to have them
2. Signal lever on right turn shuts off before the turn occurs. This has been an annoying bugger
The rig has 180K miles on her -- I have had her since October.
