No headlights or hazards!
NOVA
My second post today. My LJ78G has a preplexing problem. Headlights and hazards are not working. Yet the fuzes and fuzeable links are good. Any ideas on what could be the cause? I hate dealing with eletrical issues so hopefully someone has some advice or experience. Thanks in advance.
You could get a test lamp and ascertain the headlights have/have no power.
You could also follow the headlight wires back to their relay on the inside fender
The relay should make a faint click if they are working.
Check that the wires are plugged in.
The hazards have a flasher unit like the indicators,its probably not working.
Did these things happen at the same time without reason?
Yes, strangely both faults happend at the same time. I was leaving work to go home and noticed the road was darker than normal. Hopped out to check the lights and they were out. So, I thought I'd better be safe and drive with the hazards on. Went to turn on the hazards and they were out as well.
Thanks for the advice, I'll check the relay tonight.
Thanks!
Got the lights working again. It was the relay. Now, all I gota do is find a replacement part. Thanks again for the advice.
I think Bosch make one .
