On the 1975 US-spec FJ40 wiring diagram, it illustrates only a single fusible link at the positive terminal side of the battery. The alternator's charge terminal runs into the dash to the ammeter, and then back again into the engine bay to the battery's fusible link at the positive terminal. Also, the alternator's charge terminal runs to the ignition switch to the starter, or thru three sources, to the fuse panel. Between the alternator via the ignition switch to its ultimate destination (starter or fuse panel), and then again from the stretch between the alternator, into the cab, and nearly the whole way to the battery's positive terminal, there is no short circuit protection.
Should I install a fire extinguisher on the roll bar, or a fusible link at the alternator?
