No Fuel when Starting?
First of all thanks so much to the website developers and administrators for providing this amazing TLC resource.
OK here's my problem:
When starting the engine after it's been sitting (for a few hours or overnight) it seems like it's not getting fuel. I'll depress the accelerator pedal but it studders as if fuel is being delivered intermittently or not at all.
Here's what's been done by the Toyota dealer so far in regards to this problem:
- Cleaned fuel injectors/throttle body
- New accelerator cable (they said it was stretched out)
This doesn't happen all the time so it's been difficult to diagnose (at least for me).
I've had it at the dealer several times for this but they cannot seem to diagnose the problem. After reading Romer's thread: https://forum.ih8mud.com/80-series-...es-faq-item-recommend-keeping-copy-truck.html I'm thinking it may be the Fuel Pump Relay.
Before I try to check fuel pressure or clean the contacts in the Fuel Pump Relay is there anything else anyone would recommend checking/doing?
Thanks in advance!
you need to get a fuel-pressure Gage on and check the pressure. it is supposed to hold pressure on the system for a certain amount of time. if it does not hold you will have a very long crank sometimes can be over a minute or so before pressure builds back in the system. if that is the case a new fuel pump is needed. i had a long crank issue on my 94 and found the fuelpump to be bad. replaced it and starts every time and idles better to. that could be just me though. i have a spare relay if you need it let me know
Thanks for the info and offering the spare relay! You'd think they would have caught that at the dealer.
Did you replace the fuel pump yourself? I've been that guy that brings his car(s) to dealer for everything and would like to start wrenching at home Just wondering what I'm getting into if I buy a new fuel pump and try to replace it myself.
yes i did it myself. if you get a factory Manuel for the rig it takes you through just about any repair step by step. i removed my tank to do the fuel pump because i had to replace a broken vent on top of the tank but you can do the pump without taking the tank out. like i said get a factory manual and you will be set...
