No brake pedal feel?? Normal?
So my 94 stops fine and there is no sweaks or squeals, but the pedal feels excessively weak, no feedback. Is this normal? fluid is fine and ABS does work just fine, tested it on ice. I haven't checked the pads, but the truck stops without a problem, just very little pedal feel
Thanks
feel as in what?
surely, you hit a resistance at some point before hitting the stop, right?
feel as in what?
That's what I'm saying, You can hardly feel any resistance. The brakes grab and the truck slows, but the pedal pushes really easy all the way through the range
so, there is no resistance, the brakes engage, and still no resistance until your pedal hits a mechanical stop?
if so, that's not what I feel.
I feel a resistance that is getting progressively higher as I push in and the brakes grab progressively more.
I would have to push hard and overcome a noticeable resistance to engage the brakes to the wheel lockup/ABS kick-in level.
It is certainly not a sharp on/off feeling. If anything a tad mushy compared to the 100.
Hard to describe. Try driving another 80.
Ok, I think I need to bleed the brakes or something. You can easily push the pedal untill the ABS engages. The truck does stop progressively sooner the farther you push the pedal, but the pressure it takes isn't noticebly more. Its more than mushy
