No Brake Lights!
Seattle, WA
To make a long story short, I just got done wiring a trailer about a month ago. I also put a new a connector on the back of truck for the trailer. I checked this truck with a different trailer and the lights worked. I checked the trailer with a different truck and it's lights worked.
Now to bring you to today's excitement. I connected the trailer to the truck and went to the store. Loaded the trailer and before I left I checked the lights on the trailer by turning my left blinker on. It was blinking on the trailer and everything was fine. I pull away from the store and at the next light I put my left blinker on again and nothing happens. Both my left and right blinkers are not showing that they are blinking at all, even on the truck. I get back to the house and the brake lights and blinkers are not working at all. My hazards work just fine however. Also, my selector for the transmission all of a sudden is going into some sort of lock mode where I have to manually press the override button to make it go into gear from park. I checked all the fuses and nothing. I check the connections for everything and still nothing. My next thought is flasher and relay. I replace the relay in the engine bay on the passenger side and nothing. So my thought is that it must by a relay underneath the driver side foot well that controls the blinkers.
If that is true, then why did the trans relay blow as well.....or is there something I'm missing. AND more importantly, why did any of this happen to begin with? The wiring for the trailer connector on the truck was done perfectly with no shorts and has been tested on other trailers. Any help is much appreciated.....
Joe
I just had the same problem with my truck. All my lights worked fine on the trailer and truck but after I was done with the trailer I had to use the release button to put it in gear. All that I did was change the fuse for the break light and it was fixed. So i would check the fuses again! also when I looked at my fuse it looked fine so i was confused to but I just thought to put in a new one to see what would happen and it worked.
cheers
with the trans locked, it's likely the brake light circuit interrupted (well, at least if the 80 is like the 100, I forgot).
check fuse, bulbs, pedal switch, any wiring into the brake lights due to trailer wiring.
If it's the fuse, look for the cause (short?)
I had a problem a while back where the use of the turn signals was blowing my brake fuse. It turned out to be a faulty trailer harness - specifically the signal converter box. Changed it out and never saw the problem again.
I posted my reply in the wrong thread.:doh:
You have your answer above. Faulty trailer wire harness.
It is behind the right rear quarter panel.
Replace w/ one from Hoppy. Good to go.
Faulty trailer wire harness? I looked in my FSM and could find what or where this is... behind the passenger 1/4 panel? Also, why would this fail?
Maybe from shoddy work? Weren't the trailer plugs/wires and hitches port or dealer installed? Or maybe even installed by the PO of your truck.
FWIW, I kept blowing tail light fuses do to my trailer wires being melted and grounded out on the exhaust pipe. The turn signals and brake lights worked, but the tail light wouldn't illuminate with the head lights turned on.
LOL, and wont fix your CDL light ;)
LOL, yeah, what a brain fart! Ask me about Prep H and whiter looking teeth, too!
My understanding is that the trailer harness has a relay that is prone to failure, which causes a short in the brake/turn signal which in turn is electronically connected to the transmission release mech. Hence, if the relay blows, the brake light fail and can't get out of Park.
Pop that right rear quarter panel, removed said wires from the harness, which is easily traced from the trailer light connector and replace w/ a Hoppy brand. Recommeded to me from people who know. No problem now.
Agree with reconranger on everything he's recommended. You blew a fuse. Truck won't shift out of park if the brake light circuit is out unless you stick a screwdriver down next to the shifter.
Only other thing it could be is extra lights. Do you have an ARB up front and perhaps a Kaymar on the rear with extra lights now on the circuit. Several of us have had that issue. Dangerous fix IMHO is a 15 amp fuse (10 amp is std on this circuit). Not advisable. I solved my problem first by just disconnecting the ARB running lights when I towed. I eventually rewired and replaced all the lights on the trailer with LEDs. Solved the problem permanently.
You can just unplug the trailer ligts plugs from the harness in question to keep from blowing the fuse until your replacement comes in. Will save you from replacing multiple fuses.
Brent, your LED solution is intriguing. Was it plug and play or did you have to mod?
Recon - plug and play to a 7 pin harness on the trailer. You do have to run all the wires and rewire the harness, but that's easy. Purchased at a local Pep Boys - LED Trailer lights prepackaged. Not only are they brighter than the crap lights that were on the trailer, but with the reduced draw it solved my fuse issue too!
Unbelievable! My brake and turn signal fuses were burnt out at the very base....so when looking at them from the top they looked good. Mother F*cker! I was doing some serious trouble shooting here. I switched out my signal flasher...thinking about re-wiring my truck and trailer. My trailer has LED's so I'm not sure why this happened though. My ground on my battery was not very secure, so it could have drawn more amperage and when I turned my blinker on with my foot on the brake it must have popped both. The brake fuse solved the trans lock situation as well. Thanks for help everyone! It was a f*cking fuse....... :bang:
