NGK coil wire
Ghostrider I
I wear many "heads" as I have many vehicles.
Charlotte NC
I was replacing the plugs, cap, rotor and wires and I noticed that the coil wire that NGK supplied did not look like the picture. It was the opposite-female end. Any ideas? I really don't want to use the old wire.
Did you get the ends mixed up and putting the wrong end on the dizzy?
Nope
Well then you were given the wrong cable, if you have enough slack, you can re-terminate it correctly and you may be able to steal the boot from the old one. I've had to do it when new ones weren't done correctly and sometimes you can just do a better job than what the factory is doing and measuring.
