Newest upgrades... :)
Austin, Tx
So like every vehicle I get, I end up joining a forum pertaining to that vehicle. After reading many posts and viewing many pictures I chose the typical lift that everyone else uses.
I got it installed this weekend. I went with Js and Ls. I used MAF caster brackets. I didn't install adj. panhards, or uppers. I plan to build some here before too long. I thing this will suffice for now. Or atleast until I get a little moer wild with it. So far no vibrations, no bad handling and just a little bit of stink bug. But the 4x4labs bumper or my own home brewed bumper ought to take care of that. I still am torn between an ARB front bumper or a tube design similar to this below on our other truck. I am about 90% sure I won't get an ARB for a few reasons. 1.) Too heavy, 2.) everyone and their brother has one, 3.) blocks too much airflow in my opinion, and 4.) COST!
I also decided to install not one but two aux cooling fans after wheeling mine and getting very warm, despite having what appears to be a clean radiator and a good working fan clutch. Wired both up to one lighted switch in a factory slot in the dash. Anyways. Tell me what you think. Also I am not finished with the sliders and plan on tying them into the front and rear bumpers.
Thanks,
D
First pic is the lift, 2nd is of the bumper on our other truck, 3rd is my other toy, and 4th was just a customers truck for s***s and giggles.
And here are pics of my fans...
Nice!
How tough was that fan on the trans cooler to fit? Brand/installation?
Did you adjust your bump stops down?
Nice!
The install was easy. I did have to clearance the grill ALOT. Spent several minutes with a 4" grinder to clear the fan on the tranny cooler. I did manage to get it to fit with 1/8" gap between the fan and the grill.
The 10" fan on the tranny cooler is a Hayden unti from my local O'Reilly Auto Parts, cost was 42$. The 12" fan is also a Hayden from the same place and cost was 51$. The 12" fan advertises 850cfm through a radiator, and the 10" advertises 650cfm. May not be ALOT of air flow, but I am sure it will be better than none. I hope to find out tomorrow. Both are wired to a relay and then ran inside to a toggle switch. I had no intention to use these for anything other than fourwheeling. Hopefully they will do enough to justify spending around 100$.
As for bump stops; I did not move them. If it becomes a problem I will make drops for the bumpstops.
Daniel
